Can't Remove Tub Drain
I have what I assume is a "roller ball" tub drain in my bathtub (lift to drain, push down to seal). The tub is clogged and I need to remove it.
There is not a screw underneath the stopper and I have twisted this thing counter-clockwise until I am purple. It has not moved at all.
Am I missing something here?
Please help, this is driving me crazy.
Received 0 Votes
Try to access the trap from the overflow plate. The obstruction is probably in the trap not in the run that goes horozontal under the tub. If this is a replacement drain it could be epoxied on
There could also be a set screw holding it on. you can see it when the drain is in the up position
Was the tub refinished?
See here.
http://www.lowes.com/lowes/lkn?actio...RepTubDrn.html
See here.
Tub doesn't appear to be refinished. I just bought this place a few months ago.
I found the Lowe's site you linked to before I posted here ... heh. I thought I had the problem solved.
There is no screw underneath it. It has all the characteristics of the "roller ball," but will not/doesn't unscrew.
I cleared a tub upstairs recently simply by removing the drain screen and removing a ton of hair (which I suspect is the culprit here). Luckily, it was a "plunger-type" with the visible screw on top.
This is driving me insane. It HAS to come off somehow
Help ... someone?
Help ... someone?
Received 0 Votes
What are you using to try to unscrew it? Some of them are pretty tough.
I would suggest maybe posting in the plumbing and piping forum
After a month, I have finally fixed this problem. I am posting this in case someone has a similar problem.
As stated before, the stopper is a "roller ball." Normally, these simply screw off to expose the catch in the bottom of the drain. Some models have a screw underneath the plug sealer. Mine had one extra feature. The actual knob that is used to pull the tub drain open unscrews from the stopper stem.
In order to get this open, I used a set of needle-nosed pliers to grab ahold of the stem underneath the stopper. I then used adjustable pliars to unscrew the "knob" from the stem.
Sounds simple enough, but nowhere on the internet did I find a "roller ball" stopper that was put together in this manner (i.e. the extra screw-off knob).
Thanks to all that attempted to help.
By the way, I am replacing this with a traditional trip lever model.
Received 0 Votes
I also had a clogged 'roller ball' bathtub drain, and I was finally able to clear it after reading chickenstar's tip.
The solution was to hold the drain stopper from turning with a 9/16" open end wrench around the flats on the stem under the stopper. I could then unscrew the cap from the top of the stopper with a pair of pliers. This exposed the hex head on top of the stopper shaft so I could unscrew the shaft from the drain.
It turns out there was a ton of hair caught around the drain fitting. It would have been impossible to clear this hair without first unscrewing the stopper.
Thanks so much for the tip chickenstar.
Received 0 Votes
I had a drain plug that used to small tabs for extraction. The dumbell bathtub drain puller was too big on one end and too small on the other. I also tried the basket holding tool but it was too small as well. Three hardware stores later, I determine that this is a mythical tool that I had to stop searching for, so I did.
As a new homeowner, first time, I want to do everything the way you are supposed to and save the shortcuts for later, the right tool for the job kind of thing. That is the objective, but not necessarily the reality. So, without further ado, the extraction of a two prong tub drain....
Tools:
6" 150mm Crescent wrench (cheap is good, $1.99 at Wal-Mart)
10" 250mm Crescent wrench (for the turning of the plug)
1 Pesky 2 prong drain plug
Insert 6" Crescent into drain, adjustment side up, leaving yourself room to make a 1/4 turn of the drain. This will save you some time. Next, align and tighten the larger 10" crescent wrench to the smaller wrench about an inch or two above the head or the hole. Realign the smaller wrench (big wrench still attached to little wrench) with the two tabs and test lightly to see if you turn the plug without slipping off of the tabs. Finally, using the space you left for turning, the 10" wrench, and some light elbow grease, turn the wrenches counter clockwise. You should apply pressure gradually to make sure you do not snap the crescents or damage the tabs inside the drain. If all goes well, your drain plug should be turning. If not, you might try something to loosen any rusty or otherwise stuck spots.
Here is a short slideshow of the what and how for this. If you can't see it, sorry. It is just for illustration purposes and I cannot post HTML in here or images directly. Copy and paste this link into your browser and it will take you to Photobucket.com where I have the slideshow.
Good luck.
http://s133.photobucket.com/albums/q65/BrandyWB/Public/?action=view¤t=1169382278.pbw
Tools:
Good luck.
Received 0 Votes
stem
Ok i used the 9/16 to hold on underneath the stopper thing to get the knob/cap off. There is a stem that i cannot remove for the life of me. Am i too weak? Previous posts indicate a hex shape. I do not know if its stripped but mine is round and pliers cannot get a good grip
Received 0 Votes
You trying to change out the whole part that goes through the drain hole in the bathtub? Why are yo trying to remove the stem? What is your objective?
Received 0 Votes
PLease HELP
Received 0 Votes
finally got the drain plug out
My drain plug did not have a screw underneath the nob, did not have a set screw underneath, and did not have a hex shape under it so i could grip it with a wrench. I have a jacuzzi whirlpool tub and i ,had to put a rag over the top of the drain so i didn't ruin the finish, then with it in the down position grab it with pliers and turn it counter clockwise the shaft went down about 2 inches and had a screwed end. It was screwed into the cross section of the drain where all the hair was trapped.
Received 0 Votes
I never have to take mine apart--I plug the overflow with a wet rag & use a plunger--works every time--I also run hot water twice a week for 2 minutes to help flush crud down drain
Received 0 Votes
Plumbers have specialized tub-drain removers and pop-up plug wrenches for this purpose, but you can make your own drain remover with a pair of slip-joint pliers and a beefy screwdriver. Slide the pliers' handles down the drain, past the X-shaped metal arms or crosshairs inside, then put a screwdriver between the handles and use it like a lever to unscrew the drain. At first you'll need a bit of muscle to break the putty's grip, but once you do, the drain usually comes out easily. If the crosshairs are broken or missing, you'll need a tool called a drain key, which can be tightened against the inside of the drain. You should be able to find one through a plumbing supply house or plumbingworld.com.
Received 0 Votes
Received 0 Votes
Mine was different
Mine was similar, but different from any I've read about here - small screw off knob at the top, but underneath was a 1/4" socket receptacle (at least that's what it looked like). I grabbed a socket handle, pushed it in, and unscrewed the spindle/bolt holding down the main stopper. Came out in a flash.
Clues here definitely helped me figure out how to best this challenge - thanks to all who contributed, and I hope my experience helps someone else down the line.
Beer 4U2
Beer 4U2
Received 0 Votes
Fizzy
Chickenstar, you're a rock star! Just moved into a 3rd floor apartment & was about to take a sledge hammer to the stopper! I just joined to let you know you're instructions are beyond perfect - ETERNALLY GRATEFUL!!!
Received 0 Votes
Square head under roller ball
When I removed the ball from the stopper, the stopper had a square head shaft, so I used a thin flat head screw driver that fit inside and unscrewed the stopper from drain. Hair and conditioner were clogging the drain. All fixed now, thanks, these are the only postings that know this drain plug situation.
#21
Received 0 Votes
Thanks for the information Chickenstar! I have been trying and trying off and on for a few weeks now to get our tub plug out and this did it for me! I was able to clean out all the hair and residue and added in some drain cleaner for good measure. No more showering in a lake!
Thanks again!!! Beer 4U2
#22
Received 0 Votes
Why didn't I think of that?!!!
Of COURSE! Grab the post from underneath the cap...its soooo simple I am kicking myself for not thinking of it! I was about ready to grab the lid/cap while turning the knob...so I am glad I checked here first.
I took a set of pics so that others can see what probs we're having and to help others. Those who mentioned that their posts were not a hex or screw-driven or anything, I empathize and think that maybe using some good pliers will still work. No promises however.
When I got my knob off, there was a post that looked like it would unscrew with a flathead screwdriver...but it wouldn't budge...or more precisely, the slot was too shallow for a flathead to be effective at all.
I pushed downward on the cap/lid to fully expose the post.
And then I relied upon a tongue-and-groove set of pliers to crank it counter clockwise, and it unscrewed beautifully...but I did have to grip the pliers REALLY tight. But once I had the grip, I really didn't have to crank that hard to unscrew.
From there, I took a coat hanger and got as much hair out as possible (lots), then plunged since it was still slower than it should be. These repairs were done AFTER I had used liquid plumber gel yesterday. So I am sure that the gel also helped clear out some of the mess if only a little. Good luck to you all, and thank you to those who posted and helped me!
#23
Received 0 Votes
Thanks
#25
Received 0 Votes
thanks!!
Thank you, chickenstar and cancleaner! Such a simple solution to an annoying problem!! And let me just add, I about lost my lunch when I laid eyes on what was stopping up my tub drain ... not hair, since I never wash my hair in the tub, but something that I can only call "soap fossils." Has anyone ever seen that? They were basically small rock-like formations of old soap scum and skin cells, I'm guessing. Disgusting. But so glad it's gone and my tub is draining properly!!
#26
Received 0 Votes
used a flathead screwdriver and voila!
I had the same problem as originally described on this thread. I was going crazy trying to twist off my drain cover and it just wouldn't budge!
My drain is the type that twists/pushes down to seal and up to drain. A small knob on top of the cover screwed off easily, leaving the flange around a round stem with a square shaped center. I don't own many tools (as a mid 20s single female homeowner, I've been buying tools only as I come to need them) but was finally able to use a larger flathead screwdriver to remove the stem and flange on the drain. I'm sure this isn't the proper way to do it, but was much better than buying or renting a drain key or having to hire a plumber!
From there I used a wire coat hanger to remove the clog. The amount of hair I got out was disgusting to say the least.
Thanks for all the guidance!
#27
Received 0 Votes
It took me only one minute to fix the problem after watching following videos:
Bathtub Lift and Turn Stopper Clean How-To - YouTube
How to remove a lift-and-turn stopper in your bathtub. - YouTube (I didn't remove the screw; I just follow the first video)
How To Properly Remove A Lift And Turn Bathtub Stopper - YouTube!
FIY clean the bathtub drain - YouTube
