Low Water Pressure
Low Water Pressure
My Home Has Very Low Water Pressure. I Looked At All Of The Supply Lines To Yhe Faucets And They Are All 1/2 " Pvc Does This Have Anything To Do With It. I Am Running Off Of A Well.
PVC shouldn't be inside of the home, only on the outside. I would take all the isolation valves apart and determine area by area if you have established flow up to this point. Could be debri causing your problems.
