toliet fill valve not working
Old 12-07-05, 09:50 PM
Ramrod48
Heres whats going on , flush the toliet an it just trickles out the fill valve, its a ole fluid master valve . I removed the top of the fill valve an turned the water off an on with a cup over the valve , to try an flush any trash outta the line , has very good water pressure.
Put the top of the valve back on an it worked great for like 4-5 flushes, an then goes back to the trickle again ,, All total now I have done this like 20 times now, It seems if I turn off the watyer supply an then turn it back on the vale works ok , but otherwise it just sits there..
Any idea what may be wrong do I need to replace the fill valve ???, or have I missed something ???
Any help would be greaty appericited, Thank You ,,,,,, JIM
Old 12-07-05, 10:13 PM
majakdragon's Avatar
I think for the $6 I would replace it with a new Fluidmaster 400A fill valve.
Old 12-13-05, 07:30 PM
H
i agree but if you are on a budjet there is a gasket you can replace but its easier to replace the whole thing
