Can't get tub in
Can't get tub in
This is really dumb, but we removed our old tub, bought a new one the same size. We put down durock. We are now ready to place the new tub and we can get it into the old space. It's an acrylic tub and we can't it!!! What are we doing wrong? HELP!
I had the same problem once, both the new and old tubs were the same lenth but the new would not fit, smacked the 2x4's with a sledge hammer 2 or 3 times and the tub fit, good luck.
Tub
Acrylic tubs are usually attached to the stud, if you have changed the dimensions of the tub opening it will not fit. Check the size that the manufactor recommends, if that dosen't match thats your problem. Luck.
Tube wont fot
If you have added anything to the opening that changes the dimensions thats your prob. A standard tub measures 60 in. if you have less than that, thats where the problem lies. FYI they should have at least 60 1/4 inch. Messure your opening. Luck.
