tub over flow leaking
Old 01-18-06, 08:35 AM
H
hi,
we discovered a huge stan on my ceiling in the dining room. after some searching, we have discovered that the tub is leaking directly above. we have narrowed down to the overflow hole in the tub. after i open the cap, i dicovered gaps from 3->9 o'clock area where the pipe attaches to the tub. the orange color 'putty' has pulled away from the tub and is dry and crumbly. does anyone know what material is that? and how the replace it? i don't have access to lift the tub but does have enough room to squeeze in caulking. but, since the original material isn't caulk, i thought i should ask here first.
thanks
hash
Old 01-18-06, 08:51 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
The orange stuff may not be putty but a gasket. Tub overflows come with a gasket originally. You could use an exterior grade silicone caulk. Be careful not to slop it all over. A small bead should be sufficient. I would try to find a gasket first though. If you silicone it and ever have to remove it again, it will be a real pain to remove and to clean off the old to reseal the cover. Good luck.
