Plumbing triple bowl sink w/food disposer
Old 02-02-06, 01:19 PM
A
HELP!! We're remodeling a house we just bought & we have a triple bowl sink. It has 2 large bowls with a small bowl in the center for the disposer. How do I go about plumbing these lines for drainage please?
Thanks
Old 02-02-06, 06:33 PM
Come out of the disposal with the black turn down piece that comes with it. From there connect the piping from the 2 basket strainers with a center outlet waste system and then the disposal to the two basket strainers with an end outlet tee.
Make sure that the end outlet tee is not baffled so that you can use it as a directional tee. If the disposal turn down piece makes the whole piping system too low for the drain pipe in the wall, remove this piece and come out of the disposal with a tailpiece and directional drain like what is found off of end outlet waste kits. Works every time and makes for a quick installation. GOOD LUCK
