Inspector requires "anti-scald valve"
Old 02-09-06, 12:06 AM
T
I have a 3 handle standard Price Fister tub/shower valve set. It is new and installed. The tile has already been installed as well. Fortunately the wall on the back side is open and accessible.
1) Can I install an (in line anti-scald device) between the shower head and the valve body? And dose such a device exist?
2) Am I required to provide scald protection for the tub filler spout as well?
------Inspectors are people to------
Old 02-09-06, 06:50 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
I have not seen a seperate anti-scald device. They are a part of the tub/shower valve. Good luck.
Old 02-09-06, 10:26 AM
T
ok but
Have you ever seen a standard 3 handle valve which is code complaint????
Old 02-09-06, 10:33 AM
Most people are going to the single handle faucets so I have not seen a 3 handle anti-scald faucet. Not to say they are not made. At the top of the Toilets, sinks, showers and Tubs page, there is a list of Manufacturers that contains their Websites and Toll free phone numbers. You may want to check there as your manufacturer is listed. You could call and inquire what is available. Sorry I can't help any more than this.
Old 02-09-06, 09:15 PM
fixitron's Avatar
Anti-scald shower valve
I have seen advertisements (several times) for an anti-scald shower head. Google or check with a plumbing supply.
Let us know what you find.
Old 02-09-06, 10:53 PM
T
Angry will a tempering valve work?
I called Tod's Plumbing in GG. They say they have something that can balance or equalize the hot and cold water pressure. They called it a
"tempering valve" it costs $80. They said it looks like an "H" and is connected to both supply lines before the shower valves. It is made by Precision Plumbing Parts. Model# TRB-2.
It seems to me this device will only stabilize the showers temperature. And ultimately dose not stop scalding hot water.
! But at least I know I will be scalded evenly! ha ha ha
Can this device satisfy any code requirements?
Old 02-09-06, 11:33 PM
The final say in this matter is the local authority that enforces codes.
My one and only question; how did this valve get installed when most plumbers understand that all tub/shower or shower only valves have to be pressure balanced?
Add on devices involving tempering might not sit well with the inspector, who knows.
If it was my house and I knew of the complications involving the issue at hand, I would be removing that faucet and installing a pressure balanced valve and looking back at it as a "burp" in error and a "memory" in time. :nfunny:
Old 02-10-06, 01:27 PM
T
ok
It was installed by the type of plumber who connects copper and steel pipe together, and the kind who don't use thread sealent on pipes feeding the tub filler spout because they are not under pressure for vey long.
I am trying to avoid modifying the holes in the tile. Because the tile is new and looks great.
If I must switch to a new shower valve what brand and model do you like. I mean is there a valve that is considered reliable and or maintenance/leak free?
Old 02-10-06, 06:49 PM
The very first thing I would do is report this plumber to the licensing board and hold him accountable for his actions. This type of foolishness has to stop at some point to protect the good of others. There is nothing worse than having plumbers like this giving others in the trade a black eye. Check to see if there is a contractor watchdog community in your area.
I personally like the Delta pressure balanced assemblies. Comes in a vast array of styles. Moen comes in second but they are a pain to service sometimes. Sticking with brand names is the best bet in all cases. Easier to deal with parts down the road.
I'm sure the tile looks nice, but you have to look at the situation of what happened and correcting it so you never have to look back. Removing that tile and getting it correct is in your best interest, keeps the plumbing inspector happy which is top priority.
What is this plumbing inspector saying about this shoddy work? I hope he isn't defending this crap.
