Toilet tank has "delayed" refill???
Old 02-09-06, 04:34 AM
Sorry if this already appears in here somewhere, I tried to run a search on this, but came up empty and I don't even know if I'm describing it correctly? Basically what is happening is the toilet will flush seemingly smoothly, then, about a minute to two minutes later, the refill of the tank will begin. It seems to be delayed???? I've tried looking in the tank, nothing seems to be out of place, hopefully someone else knows what I'm talking about
Thanks in advance for any assistance you all might be able to offer
-Sharon
Old 02-09-06, 06:43 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
hi
replace the filler valve
only cost about 5 bucks
seams the plunger inside the old valve is worn out and sticks
Old 02-09-06, 10:03 AM
Thanks so much! I'll give it a try Here's my next dumb question - how do I know where the filler valve is??? DH travels a lot and this has fallen in my lap to take care of
Old 02-09-06, 10:16 AM
majakdragon's Avatar
The fill-valve is where the water supply tube goes into the tank. You will have to turn off the valve on the water supply under the tank and then you can flush and dry out any water remaining. If you purchase a Fluidmaster 400A fill valve at Home Centers or hardware stores, they have excellent installation instructions. Cost about $6. Good luck.
