American Standard fill valve - how does it work?
Hi,
I replaced my bad fill valve with an American Standard version a couple of years ago. It has a black shaft with a big yellow body on top and a screw-on top. While I was replacing the flapper valve tonight, something happened to the fill valve and it got stuck open.
I opened it up, and it has some sort of gasket assembly that wasn't obvious how it worked. And now it's even worse, it's leaking from under the screw top as well.
Anybody know how these things work? And if I could even fix it?
Thanks for any help
ken
Thanks for any help
ken
The Fluidmaster 400A is what American Standard is putting in their toilets now. About $6 at Home Centers. Easy to follow installation instructions and also has troubleshooting guide for any problem later. Good luck.
Originally Posted by majakdragon
The Fluidmaster 400A is what American Standard is putting in their toilets now. About $6 at Home Centers. .
Thanks everyone
ken
