Very Low Water Pressure in Bathroom Sink only!
I would suspect a bad washer on the faucet that leaks. The pressure problem MAY be deposits blocking the supply tube. If you have shut-off valves under the sink, turn one of them off and disconnect the supply tube at the valve. Hold a rag over the valve and turn it on and off 2 or 3 times. This should dislodge anything stuck in the valve. While you have it disconnected, hold a container under the supply tube and turn the other faucet on. Sometimes the water will cross over and flush the tube out also. Good luck and reply back with any other questions.
Previous Thread
Next Thread
