Slip washer direction
Old 05-01-06, 08:16 AM
T
Which way do the slip washers face in a plastic slip jam nut coupling? Maybe that's why it's leaking. Thanks
Old 05-01-06, 08:57 AM
E
Flat end against the nut, tapered end against the connection.
Old 05-01-06, 01:00 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
While you have it out, check the surface for defects and give it a pull. Sometimes they crack and you won't notice it. Check the inside of the pipe you are connecting to also for debris. Good luck.
