HOT shower!
Old 07-18-06, 02:36 PM
W
Angry HOT shower!
I have a single handle Price Pfister tub/shower valve with a diverter on the tub spout. Since I replaced the cartridge the water that comes out is only hot unless I close the cut out for the hot water. Turning the handle from one extreme (12 o'clock position) to the other (6 o'clock position) used to change the water temp, but does not. I have tried re-seating the cartridge, but it didn't work...what's next.
Old 07-18-06, 02:42 PM
majakdragon's Avatar
Are you sure you installed the cartridge in the same orientation as the old one? It is possible to install some of them 180 degrees different. This will change how the faucet works. You may want to pull it out and rotate it a half turn. Good luck.
