jeanlfr (Noise in wall/pipe)
Old 02-20-07, 05:29 AM
Smile jeanlfr (Noise in wall/pipe)
I have a toliet that after it is flushed and tank is filled there is a type of groaning noise in the wall (Pipe). What could be the problem?
Old 02-20-07, 06:41 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! What is probably happening the fill valve is vibrating, trying to close off the water, and it can't decide to shut it off or let it run, so it sounds like a pipe chattering. Turn the water off to the toilet, and remove the cap (1/4 turn CCW) of the fill valve. Holding a cup over the valve, turn the water back on for a few seconds. This will help flush out the crap that gets caught up in them. Replace the cap, and try it again. Let us know if it works, or if we need to come up with another scenario.
Old 02-26-07, 06:08 AM
Thumbs up Noise in wall/pipe
Thanks, you were correct. Problem solved this weekend
