Toilet Bowl Flakes
Toilet Bowl Flakes
After I flush my toilet, small flakes float out of the drain pipes back into the toilet bowl. I have used a brush to try to clean out the pipe but it does not work. Any ideas on what I can do or use to correct the problem? Thanks
Jess
Jess
either the water flow from the toliet isnt enough to clear the bowl and things are coming back up. Or your drain pipes need cleaning...if everything is going down ok then i would suggest a drain treatment chemical...hard to say without seeing what it is actually doing
