Has anyone fitted a drop in tub before????
Received 0 Votes
Hi all,
I am trying to figure out what part of a drop in tub bears the load/weight.
I have not purchased the tub yet, and I am not sure if I will go with a drop in version. I have been researching the frame that needs to be built, and it would seem that all of the weight will be supported by the rim of the tub. Is there nothing that needs to be built underneath the tub (between the tub and the floor) to support the weight?
Any advise would be greatly appreciated
Drop in tubs are supported by the tub base, not the rim. Put a layer of dry set mortar on the subfloor, install the tub with spacers under the rim equal to the thickness of whatever your finish surface will be (i.e. tile, cement board and a small (1/4") expansion gap). Press the tub into the mortar until the rim rests on the spacers. Once the mortar sets up, remove the spacers and finish off the deck.
Received 0 Votes
Ahhh, so they are all different. Thanks Rockpro.
