Can't find new seal for Enviro-Tech Faucet
Received 0 Votes
Apparently the Enviro-Tech brand is no longer available and I can't find a spring and seal set to repair one. Anyone lnow who has one or what else will work?
Received 0 Votes
Yes Susan I used a replacement seat and spring kit manufactured by danco. I bought it at Home Depot. The packaging says Delta/Peerless DL-17. Don't use the provided springs re use your old springs. Here is the manufactures website if you can't find it www.danco.com
Received 0 Votes
I went to Lowes and got Brass Craft #0082 seats and springs for Delta SIngle Lever. Used the shore cone springs and short seats. No issues
Large O-Ring is #0672
THe small O-Ring I left alone but it is available too.
I need the cartridge the handle goes onto because mine is cracked on one of the faucets. I tried Brass Craft #1149 for a Valley faucet. It works but the flat that locates the handle is on the wrong side and the OD is a little bigger where the handle goes on. A file took care of that and now works but I would like to get the factory replacement part.
