Leaky tub overflow
Old 07-19-07, 12:58 PM
L
Question Leaky tub overflow
Recently moved into house.Tub overflow leaks into basement corner when taking bath. Refresh me - are the overflow holes up or on bottom? Any advise on how to fix problem?
Old 07-19-07, 04:10 PM
E
Bottom.
First take the cover back off, then inspect the condition and position of the rubber gasket. Replace if necessary and/or tighten so that the rubber gasket is behind the backside of the tub, all the way around, evenly, between the tub's backside and the flange of the overflow. Some gaskets are made more foolproof in the sense that they are split open so they go both over the edge of and around the flange, and when you rebolt up the cover, the gasket has to be centered, automatically.
