Pros & Cons - Use of Offset Toilet Flange
Old 11-09-07, 11:31 AM
C
I want to add some cape cod wainscot to the walls in my bathroom and by doing so I do not have 12" from the wall to the center of the flange. I need approx 1/4 " more to make the toilet fit properly. Rather than moving the pipe (which is a major job), I was thinking about using a offset stool flange.
What are the pros and cons of using an offset tolet flange?
Old 11-09-07, 09:50 PM
P
the major con to an offset flange is that the drain is restricted and they tend to plug up at the offset. i don't know of any pros.
paul
Old 11-10-07, 08:41 AM
C
Received 138 Votes on 111 Posts
I guess the pro might be that you can fit a toilet without moving a wall.
Old 11-11-07, 12:25 PM
shacko's Avatar
Smile Toilet flange
If you are talking about 11 3/4in. verses 12 in. you should not need a offset flange, most 12in. rough-ins will work with the 1/4in. difference, luck.
Old 11-11-07, 09:51 PM
C
I missed that. I have a 12" rough in with sheetrock and tiled walls. I have about 1/2" to 3/4" clearance from the tank lid to the tile.
