Toilet barely flushing
Received 0 Votes
I've done all I know to do in my incredibly limited way
. My toilet will flush, but slowly. The bowl fills up quickly but goes down VERY slowly. I thought maybe something was trapped in the goose-neck of the toilet so I tried another toilet...same problem. I ran a garden hose into the house and put it straight into the floor where the toilet goes and it never backed up. So I figured it may be the air vents that stick up through the roof may be clogged. I got up on the roof and ran the garden hose into those vents for several minutes each with no back-up whatsoever.
I'm out of ideas! Help!
The rest of the house has no trouble though the bathtub next to that toilet does drain relatively slowly. (if that helps
Received 0 Votes
1. the toilet could be old and partially clogged with calcium deposits.
2. it could be the design of the toilet and that is how they work.
3. It could be a partial blockage(kids to, etc) in the toilet trap, you may have to do a visual on it.
4. good thinking on the vent possibility. But did you try the toilet after?? Also, one vent likely serves both bathrooms, so if one works, that is likely not the problem.
Received 0 Votes
Using a PenKnife Open Up the Siphon Hole ..Small Hole
Opposite the large Drain..
Mine Was clogged with Calcium
Easy repair..
I don't think it is a Clogged Drain..
I Had the Same Problem..
http://www.toiletology.com/toc.shtml
Easy repair..
Received 0 Votes
My parents purchased our home in 1960...we have the same bathtub and toilet. Lately the toilet flushes, once in a while...and then sometimes it just doesn't. The bowl will fill up...doesn't overflow but for some reason won't go down. We had a plumber come in and he said there might be a hairline crack in the bowl...somewhere. I have no leaks on the floor, in the basement ceiling, etc. I need another opinion before I go out and purchase a new bowl. The plumber did snake it but there was no clog.
Help!
Help!
Received 5 Votes
Hello: Sue627
Another opinion.
I am not a plumber but might have the solution. The problem description likely indicates restricted water drain/flush holes around the bowl.
Those holes are located under the rim of the bowl. Over a long time period they can become clogged and/or restricted with calcium, rust, scale, debris and/or hard water deposits in the water.
One method is to use a chemical that dissolves hard water deposits, lime and calcium. Chemicals name escapes me now...
but should be in the sticky note in this form topic.
That chemical gets poured into the overflow tube until some of it appears coming out of the holes under the rim. Allow this chemical to remain in the system for several hours before flushing. May need to repeat the process several times.
Once the above is completed, clean those holes. But do so Carefully! So as not to crack the bowl. Use a wire of lesser diameter then the size of the holes. Loosen any debris left and flush again.
The above should resolve the problem...
without a need to replace the entire toilet....
Another opinion.
Received 0 Votes
Hello: Sue627
Another opinion.
Another opinion.
Received 0 Votes
Your answer sounds like it will solve a problem i am having. However, i do not know what type of chemical you are using. Being a novice on the site i do know where the Posty note is
Received 0 Votes
adjusting water level in toilet bowl
This is my first time on this site, so if I am doing this wrong...please forgive. The toilet bowl is not filling up as much as it should. HOW do I adjust the water level in the bowl. I have stared into the tank but it didn't help. kindly be specific for this newbie. Thanks
Last edited by doris1234; 11-25-08 at 08:44 AM. Reason: I need my post in the proper place with new quest.HOW?
