32" neo angle shower?
Old 12-14-07, 06:55 AM
Does anyone know if it is possible to purchase a 32" neo angle shower base and doors or a one piece unit? Contractor says that this size does not exist and he will have to pour concrete base - i am trying to save $. thanks in advance
Old 12-14-07, 08:09 AM
shacko's Avatar
Unhappy Neo-Angle shower
maxlee: I think the contractor is right, if you find such a thing I think it will be almost unusable, sorry.
Old 12-14-07, 08:52 AM
why is that? That is what we currently have in the bathroom. It is old and needs to be replaced.
Old 12-14-07, 09:03 AM
T
32" is a tight squeeze for many. The 32" neo angle shower is available. You can Google to find. Here's one link: http://www.diamondtubshowers.com/Mai...ct.aspx?ID=109
You may have luck going to a plumbing supply. Although likely not a stock item, the 32" neo angle shower can be special order.
Old 12-14-07, 09:22 AM
shacko's Avatar
Shower
maxlee: Where I work the minimum dimension of a shower is 1024 sq. in. which comes out to 32x32, I don't see where you can have a neo-angle starting with 32 and still make the minimum. If you have one that works, replace what you have!
Old 12-14-07, 10:01 AM
what is that a minimum for? I don't really understand this stuff very well. The two long sides are both 32" long
Old 12-14-07, 02:17 PM
E
But wouldn't you have to divide 32 x 32 by 2, due to right triangle? Albeit it be larger than 1/2, due to extensions that come straight out on each side. It seems like the actual square inches would fall somewheres between 1024 and 512. Maybe 750?
