New Vanity in new basement - pipe issues! HELP!
Old 12-26-07, 03:37 PM
C
Putting in a new vanity in a newly finsihed basement. Builder roughed in the plumbing. The pipe that the trap should connect to had a 2" threaded cover with a square nut on the outside. All the piping for p traps is 1 1/4 or 1-1/2.
The only thing I could think of is just add pieces until I can get it reduced to the 1-1/2 pipe. Is that right?
I still don't get how all of these pipes connect some without any threads.....are these plastic gaskets supposed to be compression fit type connections???
Thanks for the help!
Chris
Old 12-26-07, 05:37 PM
chandler's Avatar
Received 7 Votes on 6 Posts
The 2" exit pipe into the wall is correct. You will find a nut to match it along with 1 1/2 or 1 1/4" gasket into which your waste arm will fit. From there your ptrap assembly will attach to the waste arm. Post back if this didn't clear it up.
