Wall Mounted Toilet Install
Old 12-31-07, 11:58 AM
R
Question Wall Mounted Toilet Install
Want to install a wall mount toilet.The spec is calling for a 1 in supply line, what should the minimum water pressure be for this type of application? Need to know if the supply line can be reduced down to 3/4 for the Flush Valve for 1.6 Water Closets.
Old 01-01-08, 05:06 AM
Water pressure is not altered by the size of the pipe, volume(flow) is. It depends on the toilet flush mechanism, what does the manufacturer recommend??
Old 01-01-08, 08:39 AM
shacko's Avatar
Wall mount toilet
rdruschel66: Just Bill is right, you must go with the manufactors specs.
"If all else fails, read the directions"
Old 01-06-08, 07:52 PM
Sloan Flushometers are readily made for 1" applications as it is a common requirement for commercial toilet installs.
