toilet
Old 01-14-08, 08:18 AM
D
toilet
waste drain size in concrete floor is 5 inches. Wax ring size for toilet to buy is no larger than 4 inches. How do I get a seal and connect toilet down. Toilet is American Standard.
Old 01-14-08, 11:34 AM
T
Let's get really accurate here.. Measure both the inside diameter and the outside diameter of your existing pipe. Take those measurements (and a photo if possible) of your problem pipe to a plumbing supply house (maybe even a "good" box store) and they will steer you to the proper toilet adapter for your needs... Pipe sizes are standardized in the U.S. - and you should be able to find what you need with judicious measurements.
Old 01-14-08, 08:27 PM
mikeTN's Avatar
Received 1 Upvote on 1 Post
wax ring with rubber taper available. unusual to see 5 inch pipe!! no big deal!!!!!
