wobbly toilet, tightening nuts not working
Old 01-21-08, 02:25 PM
The basement toilet was leaking, so I got a wax ring to reseat it. When I tried to undo the nuts, the screws snapped off - they had rusted out. When I removed the toilet, I found the screws had been set in the cement. I hacksawed them off and went to the plumbing supply store. They sold me a nifty PVC flange that had a compression rubber ring. I got out the drill and a masonry bit and installed the flange securely to the cement floor. Believe me, it isn't going anywhere. I tightened the compression screws to seal off the gap in the pipe. I then fitted the wax ring to the underside of the toilet and placed the screws in the proper place in the flange. I placed the toilet on the flange and wiggled it like the ring directions advised. I tightened the nuts on the screw and the thing wobbled like mad. I tighten further, still wobbles. I noticed the washers had been indented from the pressure of the nuts. Still wobbles. What can I do to get this toilet to stay still?? Please help!
Old 01-21-08, 03:48 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Buy some white nylon wedge shims and shim it on the appropriate side and cut the shims flush to the edge of the toilet.
Old 01-23-08, 10:22 AM
Terd Herder's Avatar
Along with the shims, you can also caulk it to the floor. Just leave a gap behind the toilet so you will know if there is a leak. It is more than likely it is wobbling due to the flexibility of the pvc. Good luck!
