New construction, Toilet flushes strange
Old 02-06-08, 08:00 PM
P
The toilet in my house on the second floor flushes strange. It's a new construction house so the toilet is brand new. When I trip the lever, the water seems to go into the bowl slow, like things are happening in slow motion.
When it flushes, the bowl fills and the water level rises a little as normal, then the water in the bowl goes down for just a split second and then comes back up. Therefore, whatever contents (i.e. toilet paper) that doesn't catch the jet of water from the siphon jet remains in the bowl.
The toilet is a 1.6 gal. American Standard elongated bowl with ball and flapper. I've plunged the toliet, adjusted the water level in the tank, checked the holes in the rim to no avail. Does the way the sewer pipe is routed have any effect? I think it goes down from the wax ring about 5 inches and then makes a 90 degree elbow turn to a horizontal pipe.
I have the same model toilet in two other bathrooms in the house and they flush good. Anyone know what's going on? Thanks.
Old 02-07-08, 05:46 AM
C
Received 139 Votes on 112 Posts
Make sure the flapper is opening fully. Take the tank lid off and lift the flapper by hand.
If the flush mechanism isn't the problem pick up a toilet auger at a home center. They are designed specifically for clearing blockages in a toilet that snakes and plungers often fail to dislodge.
Old 02-07-08, 06:45 AM
Also, there are two types of hand augers, one has a 3' auger length and one has a 6' length. The 6' is around $20 more, in my experience you sometimes do need the extra 3'.
Old 02-07-08, 11:32 AM
Terd Herder's Avatar
Good advice...try the auger.
