Tub Drain Leak
Old 02-13-08, 06:46 PM
T
Tub Drain Leak
We just installed a new bath tub and I have a small leak between the factory installed black plastic/rubber ring at the bottom of the tub drain and the tub itself. Is there any way to fix this. Thans
Old 02-13-08, 07:43 PM
Unclediezel's Avatar
Remove the drain....
A small glob of plumbers putty , rubbed quickly between the palms of your hands to form a "STRING"
Wrap the string around the drain , screw the drain back down firmly and your done......Wipe off the excess that oozes out into the tub.....
Good Luck...
Old 02-14-08, 03:39 AM
T
Can I use plumbers putty on a pvc or plastic tub? Is itg alright to remove that factory installed gasket or seal to put putty between them?
Thanks
