Up-Flush Toilet - Basement w/Septic System
Old 02-19-08, 07:01 AM
G
I'm planning on installing a toilet & shower stall in my basement. We have a septic system, so I would need to purchase a system that pumps the effluent "up" to the septic drain. Approx 6 ft lift required.
I've seen Zoeller makes 2 different systems. Once uses a proprietary toilet that forces effluent directly into a tank/pump assembly. The toilet can sit directly on the exisitng floor.
The other system uses a platform where a std issue toilet may sit on top, and the effluent drains into the tank/pump.
Has anyone used either type? Which is better? Any other brands out there I should consider? Pitfalls?
Thanks in advance.
Glenn
Shelby Twp. MI
Old 02-21-08, 09:45 AM
Terd Herder's Avatar
I would consider installing a ejector pit in the floor, run fittings and go from there. Good Luck!
