Question on body sprays
Old 02-20-08, 09:23 PM
Received 2 Votes on 2 Posts
How much flow is necessary to support a body spray system?
I assume you need sufficient flow rate for that. I have seen showers with 3, 4, 5, even 6 body sprays. If I have a shower mixer valve that is 1/2" cold in, 1/2" hot in, and runs a line to an overhead shower, if I set up a diverter to transfer the water to body sprays, let's say I have two, is that enough flow to do the body sprays or you need more flow? I don't want to install 2 or 3 body sprays when the water flow is not even enough for that many.
Thanks,
MC
Old 02-21-08, 09:31 AM
Terd Herder's Avatar
You have to check manufacturer specifics. Good LUck!
