Set Screw for the Faucet Handle
Old 05-11-08, 10:00 AM
T
The screw head is rounded out and I can not seem to remove it. It's a quarter inch down into the handle. Are there any suggestions someone might have in aiding me to remove this screw. My pipe is leaking and that seems to be the only way to access it.
Old 05-11-08, 10:53 AM
Go to a hardware store and get a tool known as a screw extractor aka easy out.This is a spiral shaft drill bit like tool used to remove broken off screws and bolts and will work to remove stripped set screws.You'll probably need either #2 or 3 maybe 4 depending on how large the set screw is and the hole in it.You tap the easy out into the hole wedging it in then use it to screw out the set screw as if it was the head of the screw.May be a bit difficult since most of these set screws are on the back of the handle but will usually work.
