Shower Head Neck Won't Stop Leaking
Old 06-07-08, 10:22 AM
Geobass's Avatar
Angry Shower Head Neck Won't Stop Leaking
I just replaced the fixtures in my shower and I'm having a problem getting the shower head neck to seal. It started with the joint at the head. First I used Teflon tape, but it still leaked. Then I tried thread joint compound; still leaked. I thought it might be the neck itself because the threads were cut rather shallow. So I went and picked up another neck. Now it's leaking on both ends. I used joint compound on the end going into the wall and tightened it well. Still leaked.
I'm at my wits end. Does anyone have any suggestions?
Old 06-18-08, 01:08 PM
Geobass's Avatar
nobody?
Old 06-18-08, 02:55 PM
When you say " neck " --you are talking about the short pipe that goes into the wall & screws into the vertical pipe in the wall??
What material is the " neck " made of ? Galv. ? Plastic ?
The vertical pipe in the wall is made of what material??
Can you upload photo on image shack or photobucket & post here................
Old 06-18-08, 04:48 PM
plumbingods's Avatar
It could be that you overtightened it and the fitting in the wall has cracked and will need to be replaced.
Old 06-21-08, 11:11 AM
Geobass's Avatar
Yes, that's what I'm talking about. It is steel. I'll take a pic and upload it this weekend.
Old 06-21-08, 11:14 AM
Geobass's Avatar
It's definitely not cracked. The primary leak was the joint where the shower head screws on to the pipe. The joint at the wall was fine. When I switched out the pipe with a new one, I tightened it just a bit more thand hand-tight. Hardly enough force to crack cast brass.
Old 06-21-08, 11:46 AM
Could it be cross threaded?
These parts are usually made of brass. That is why I asked about tightening too much. As brass gets old it becomes brittle. The neck piece should be chrome plated brass.
Old 06-21-08, 11:53 AM
Geobass's Avatar
The brass elbow is new. I just installed everything from the floor up.
Here are the pics...
http://i2.photobucket.com/albums/y27...Img_2870_1.jpg
http://i2.photobucket.com/albums/y27...Img_2869_1.jpg
Old 06-21-08, 12:02 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Ok, maybe its me, but I never saw a drop ear elbow for a shower with wrench flats on the outside like that.
No expert, just sayin.....never saw one like that.
Old 06-21-08, 12:25 PM
It depends on the brand. I have seen drop ear 90's like that before If it properly screwed in there should never be a need for it.
