solutions for slow or incomplete flushing toilet
We just bought a home and the previous owner had "finished" the basement. We are on a septic system. The bathroom in the basement has a toilet that will not completely flush. The flush valve and float are fine, and the water level is less than 3/4 inch from the spillway.
What do you think/recommend? Is it perhaps that this toilet is too low and there isn't enough gravity to force a flush? If so, what can be done about that?
Thanks!
Thanks!
No, it flushes, but only 1/2 of the water empties from the tank. The contents of the bowl never completely flush. I can dump a pail of water into the bowl and it flushes fine. I really wonder if the toilet is lower than the drains that existed when the basement was "finished" and therefore there isn't enough gravity. The flapper stays up long enough for the tank to drain, but it doesn't empty more than 1/2 on any flush...successive flushes have no additional effect on emptying the bowl.
Those are the indications of something being in the toilet, like a toothbrush, pen, G.I. Joe, or hairspray cap, OR a septic tank that needs to be pumped. If you know where the septic tank cover is, you might want to start there.
Get a GOOD QUALITY closet auger and snake the toilet.
I highly doubt the problem is with the piping in the basement, but I am not ruling it out.
The other thing to look at is the venting. Does the sink or tub/shower make any funny noises when you flush the toilet? Do any other fixtures in the bathroom act funny?
