Shower is SCREAMING LOUD...Help Please
Received 0 Votes
Hi All,
Thanks for taking my question.
I have a house (built in 1984 in NY) with 2.5 bathrooms and one shower is driving us crazy. Here is what is happening...when the shower is used, there is a loud vibration sound coming from behind the shower walls...note that there is NO noise or vibration if the shower is off (tub only). The noise can be reduced if we choose less water pressure.
I'll take any suggestions on how to eliminate the problem. Thanks.
John
John
It sounds like a loose washer to me.
The problem will be finding it. Do you know if there are any shut off valves for that shower? Sometimes the problem will be there. The other thing to check for will be internal stops built into the shower valve for the purpose of servicing the valve. And of course there is the chance that something is wrong with the shower valve itself.
Any more info or pictures will help.
Received 0 Votes
Thanks
Thanks for the quick reply...
I don't think there is a shut-off valve near the shower valve. I did note last night that the whole shower valve vibrates all the time with HOT water and very little (if not ever) with COLD water.
What do you mean when you reference "internal stops"?
Should I take the valve apart...it's a Delta...Handle w/button & screw - (old style RP2391)?
Sorry to be a pain, but I really appreciate your help. Thanks again.
John
John
If you take the cover plate off, after the handle, and you see a slotted screw on each side of the valve, it should mean you have internal stops. If not, you may want to take the valve apart and check for any problems.
You mentioned Delta in your second post...
Is this a faucet with a tub spout diverter?
If it is, the diverter is defective and if you replace the tub spout, it will solve the problem. Pulling the diverter in the fully open position will remove the sound if that's your situation.
If not, plan B.
If not, plan B.
Hi All,
John
John
