Single to Double Sink in bathroom
Old 11-13-08, 12:10 PM
C
Hi all,
I've replaced my single sink with 2 drop-ins in my bathroom...all's well with that BUT...
having a hard time with drain. We're 'rigging' it so both sinks drain into same pipe. I know not recommended, but it's short term until I can afford for it to be done correctly behind the wall...
Anyhow, we have a 'L' shaped pipe that will go from the added sink (drain) the the 't' connector under the original sink location. The question: How do we get the "L" to connect to the drain pipe from the sink?
Thanks,
Old 11-13-08, 05:21 PM
E
The best thing for you to do is to simply ask soemone in the plumbing dept. of where you have to buy the stuff anyway. That way we do not feel we have to make recomendations that may go against code.
Old 11-17-08, 07:45 AM
C
I did and what I was told didn't work, that's why I came here.
But...I understand.
Thanks anyway.
Old 11-17-08, 08:27 AM
E
In what WAY didn't it work? The water did not drain right? Or, the pipes did not match up right?
