reroute of sewer pipe?
Extending Lines
Thats not clear, if you have WATER lines they would have to be changed to CPVC, drain lines to PVC-DWV. Drain lines can be converted by using a Fernco or Mission coupling, water lines you can use a Shark Bite fitting depending on what you are doing, more info.
