Delta drain compatible with Kohler?
I want to replace the tub overflow cover and waste plug only on my tub drain assembly. The original is a Kohler lever-operated. On the replacement I will just use a plug to cut down on problems. Will the 1 and 1/2 inch Delta plug screw into a Kohler drain assembly of the same diameter and will the two screw overflow Delta likely fit into a Kohler assembly? I was trying to avoid replacing the whole thing. Kohler does not make a color that matches what I have replaced the faucet and showerhead with. Any help would be appreciated.
Thanks,
Robin
Thanks,
Robin
