Drain pipe in wrong place
Old 02-23-10, 03:42 PM
I am in the process of installing a basement bathroom in my home. After installing the wall behind the where the toilet will go and doing some measuring. I have came to realize that the rough in of the drain pipe is 3" short of the standard 12" needed to mount a toilet. My question is with a concrete floor would an offset flange work? and since my drain pipe is cast iron, how would that mount up to that? Thanks for any advice as I am trying to avoid tearing up the floor to rememdy this.
Old 02-23-10, 03:59 PM
Temporarily Suspended
Really, the wall is in the wrong place, not the pipe. Try to find an offset flange with a rubber gasket to go into the cast iron. It may work.
Old 02-23-10, 04:03 PM
actually the wall isn't as all the other plumbing and mechanicals for the house are on the other side of it, but thanks for the advice.
Old 02-23-10, 04:15 PM
shacko's Avatar
I think you are going to need to break concrete, 3in. offset on a cast iron pipe is a long measurment; plus you would need a inside cast iron pipe cutter, sorry.
