toilet conversion
Old 06-25-10, 09:37 AM
toilet conversion
I need to replace the fill valve on a toilet and I saw a conversion kit to give the toilet 2 flushing options for #1 and #2. I was wondering if anyone has experience/opinions with these?
Sorry I can't find a link to the actual product, it was at Costco and was around $20.
Old 06-25-10, 10:17 AM
Gunguy45's Avatar
Super Moderator
There are several diffent types out there. Amazon has a couple listed. Some use a lever that you push right or left, others use a split button, top is low flush, bottom is full flush.
The second is cable operated I believe, the first uses levers more like a regular flush valve.
There are even some that you don't have to replace the entire flush valve...they just take the place of the flapper assy.
Amazon.com: MJSI HYR270 HydroRight Drop-in Dual Flush Converter: Home Improvement
Old 06-25-10, 02:46 PM
Upvotes Received: 16
A fill valve would not give the option of dual flush, that would take a special flush valve.
I would caution against trying to retrofit a toilet to dual flush because it probably won't work. Dual flush toilets are engineered to utilize the dual flush option and trying to retrofit would likely just cause a slight dilution of the, ahem, "liquid waste" without actually doing a flush.
Old 08-19-10, 09:27 PM
Yes, depending on the type of toilet, the conversion kits may not always work. We have 3 bathrooms with 2 different types of toilets and were able to install the MJSI conversion kits on all of them!
