Updated. F.A.Q's and Helpful Information Here. Please Read This Post 1st.
This section contains answers to frequently asked pluming questions. It is meant by no means to be the quick answer to your problems, only an immediate resource for many common problems. If you need additional advice or clarification of the advice given on this page, please post a new question so we may assist you better.
Please indicate such things as water pipe what type it is, drain pipe what type it is, faucet the brand if you know, what brand of toilet you have, city or well water, and any other details that may be important.
Answers to the below question will be found beneath this section.
My toilet runs will not shut off?
Water leak on floor by toilet?
My faucet leaks?
Electric water heater not heating correctly or water is cold?
Water Heater leaks?
Water Heater Makes Noises?
Garbage disposal will not turn on?
Garbage disposal hums when turned on?
Low pressure to a faucet or shower valve singe or two handle control?
Sink Sprayer has lost pressure?
Low water pressure to shower but good pressure to tub?
High pitched sound at toilet fill valve?
Diverter to shower not sending all the water to it, half to shower and half to spout?
My toilet does not flush correctly?
Check and make sure the flush ring and the toilet blow hole are open make sure these holes are clear of hard water build-up
Is there any bluing tablets in the tank?
Remove any bluing cake drop-ins, these are a #1 cause to plug up the toilet flush ring.
Is the tank flapper staying up long enough?
If it tends to drop to fast, replace the tank flapper.
Tank fill valve operating ok?
You should have good water flow though this, including the bowl fill tube, this is the tube that comes from the tank fill valve to the overflow on the flush valve. This is the most important part of the toilet, if this is not working right you will have problems with it flushing good.
Is toilet plugged up?
There could be a foreign object inside the trap of the toilet, try a plunger or toilet auger, to clear or remove such object.
Toilet flushes slow raises to top then goes out slowly and water comes up in the tub or shower?
This indicates the mainline is clogged up, you will need to have the line cleaned out.
Check tank flapper
A worn out tank flapper will cause toilet to run, replace with a new one
Check the chain from flush handle
Too tight will cause water to leak past tank flapper making toilet run.
Check Tank fill valve
If the tank fill valve is old and worn out, this can cause the water not to shut off and will continue to run all the time. Replace the tank fill valve with a fluid master 400A
Flush Valve
Surface of the flush valve where the tank flapper makes the seal, if rough or pitted, this will cause water to leak past flapper.
Tank fill valve bowl fill tube
The tube the comes from the tank fill valve to the overflow on the Flush Valve , if it's below the tank full line. this can cause water to siphon out of the tank making the tank fill valve to turn on and off all the time.
Tank to Bowl Kit leaking
Replace the tank to bowl kit, remove chlorine tablets out of the tank, these can break down rubber parts cause the tank to leak
Wax Ring seal broken
Pull and reset toilet, make sure toilet sits even on floor, shim where needed.
Toilet Supply leaking
Replace with a new one if tightening it up did not stop it.
Try tightening up the packing nut behind the shut off valve handle,
Tank Cracked
Most likely not, but it can happen. Replace if needed.
Tank Sweating
Humidity in a bathroom can create tank sweat, install a tank liner and find a way to remove the moister out of the air.
My faucet leaks?
Single handle faucet or two handle washer less type
Most of the time it will be the cartridge needing replaced, some will need springs and seat, take faucet apart to determine what type you have.
Non Washer less type
These will have seat and stem washers, most of the time replacing the washer on the bottom of the stems will fix this, but sometimes the seat will need replaced.
Debris stuck in faucet
This happens a lot in older homes do to old water pipes, (galvanized pipes), take faucet apart and flush line clear, this debris can cause faucet to not shut off fully.
Faucet leaks through stem area
Most of the time this is solved by tightening up the packing nut behind the handle area.
Electric water heater not heating or is cold?
Thermostats not working and keeps tripping after reset
Replace both Upper Stat and Lower Thermostats Be sure to turn power off before working on heater
Dip Tube broken
The Dip Tube is located on the inlet side of the heater, pull and check replace if broke or no longer there.
Heater Elements not working.
Test with an ohm meter, replace burnt out one.
Electrical Breaker tripping at power panel
Reset breaker if problem persist, could be the bottom element out or there is an electrical problem.
Water Heater leaks?
Leaking at connections on top of water heater
Tighten up or replace flex connectors on water heater.
Leaking from bottom of heater
Time to replace the water heater
Leaks through drain valve at bottom of heater
Close tight or have it replaced.
Leaks through the T & P Valve (T & P stands for pressure and temperature)
Thermostats overheating, replace both upper and lower stats for a electric water heater.
T & P valve is bad, replace with a new one.
Thermo Expansion is taking place, install a thermo expansion tank.
Reset Switch tripped
Hit reset button most of the time found on the bottom of the disposal
Circuit Breaker tripped at power panel
Reset breaker at power panel
Disposal motor is burned up
Garbage disposals.
Garbage disposal hums when turned on on?
Jammed up inside of it
Most of the time this can be unjammed by using a Allen head wrench on bottom of disposal and turning it by hand.
Old and rusted shut
Replace the disposal.
Low pressure to a faucet or shower valve single or two handle control?
Low pressure on both sides
Check the aerator could be plugged up, remove it and clean it out.
Galvanized pipes
Old galvanized pipes build up scale in them, this alone cause low pressure, replacement maybe needed to get the pressure restored.
Washer type stems
If there the washer type check to make sure washer is secure to bottom of stem.
Check shut off valves
Make sure shut off valves are fully on.
Check for obstructions
Debris from old pipes stuck in supply lines, or stuck in stems, or stuck below the stem in the faucet, or stuck at the shut off valve. Take stem out or remove the supply line and flush line clean.
Cartridge is bad.
Low pressure on just one side of the faucet?
Same procedures as above but working with one side. Except no reason to check aerator
Sink sprayer has lost pressure?
Check Diverter
Diverter is clogged and needs cleaned out or replaced, this is found inside the spout area, take spout off to find this.
Spray Head possibly broken
Spray head could be broken, replace the spray head if broken.
Low water pressure the shower but good pressure to tub?
Check shower head
If you have good pressure to the tub spout and low to no flow to shower head, check for debris in the shower head, remove and soak in vinegar or replace with a new shower head.
Check Diverter
The divertor that sends water to the shower head could need rebuilding.
Tank fill valve makes noise like whining or sounds like fog horn
This is an indication the fill valve is in need of replacement, replace it with a fluid master 400A This will 99% of the time solve this.
See Links Below
(copy and re paste links into address bar if needed)
Tank Type Water Heater Draining & Flushing Information. Tank-less Info Included. - DoItYourself.com Community Forums
Diverter Spout Not Working
You need to replace the spout, there are two type, one that screws on a pipe, the other slips on a copper pipe.
(a) The one that slips on the copper pipe, there is a set screw that hold it on, look on the bottom of spout for a slot near back edge, inside is a Allen set screw, this will release it from thew pipe for replacement.
(b) The other just unscrews from a pipe, righty tightly, lefty loosey. It will not have a slot near the back edge.
Diverter Stem
Remove stem and rebuild it.
Additional Helpful Links:
(copy and re paste below links into address bar if needed)
http://forum.doityourself.com/showthread.php?t=157837
Electric Water Heater Draining & Flushing Information:
http://forum.doityourself.com/showth...hreadid=164120
WATER HEATER HELP LINK:
Water Heater Draining, Flushing Information, Water Leak Detection, Help Pages & Links - DoItYourself.com Community Forums
TANK LESS WATER HEATER HELP LINK:
Tank less Water Heater Help & Informational Link:
[url=http://forum.doityourself.com/showthread.php?threadid=147262]>>>FYI: Tank-less Water Heater Information With Links Included
My faucet leaks?
Water Heater leaks?
Check tank flapper
Flush Valve
Tank Cracked
Tank Sweating
My faucet leaks?
Dip Tube broken
Water Heater leaks?
Garbage disposals.
Old and rusted shut
Galvanized pipes
Washer type stems
Cartridge is bad.
Check Diverter
Check shower head
Check Diverter
See Links Below
Diverter Stem
Last edited by Sharp Advice; 07-24-10 at 12:20 PM. Reason: Update Info, Spell Check and Create Links from Text.
Asbestos Warnings
For more Info refer to link below.
Asbestos Warnings:
http://forum.doityourself.com/showth...980#post512981
Sincerely. Regards & Good Luck.
Sharp Advice, TCB4U2B2B Business Management Enterprises.
Web Site Host, Forums Manager, Monitor, Hiring Agent & Multiple Topics Moderator.
Asbestos Warnings:
1 Post
PLUMBING SUPPLIES
http://doityourself.com/plumbing/index.shtml
Tank & Tank less Water Heater Informational Links:
http://forum.doityourself.com/showthread.php?t=134483
http://www.tanklesswaterheater.com
www.tanklessheaters.com
http://www.titanheater.com
http://www.realgoods.com
http://www.controlledenergy.com
http://www.e-tankless.com
http://www.sets-tankless.com
http://www.eemaxinc.com
http://www.gotankless.com
http://www.tankless-water-heater.com/what_to_expect.htm
http://www.faucetdepot.com
http://www.irawoodinc.com
http://www.seisco.com
Plumbing Manufacture 800 #'s and Web Site Links
American Standard 1-800-442-1902
American Standard Bathroom and Kitchen Fixtures - Toilets, Faucets, Sinks, Tubs, Showers
Kohler 1-800-4-KOHLER (456-4537)
KOHLER | Toilets, Showers, Sinks, Faucets and More for Bathroom & Kitchen
Moen 1-800-BUY-MOEN (289-6636)
Faucets, Sinks & Showers for Bathroom, Kitchen & more - Moen
Delta 1-800-345-DELTA (3358)
Kitchen Faucets, Bathroom Sink, Toilets & Shower Heads, Kits, Systems & Accessories : Delta Faucet
Price Pfister 1-800-Pfaucet 1-800-732-8238
Pfister - Home | Kitchen Faucets, Bathroom Faucets, Showerheads, Accessories
Bradford White Water Heater 1-800-334-3393
Welcome to Bradford White Water Heaters. Built to be the best. | Bradford White Water Heaters. Built to be the best.
In-sink-erator 1-800-558-5700
Garbage Disposal | Kitchen Garbage Disposers | Food Waste Disposers | Garbage Disposals - InSinkErator
Sloan Valve Company 1-800-982-5839
Sloan Valve Company
DIY'S Links To Help and Information Pages:
http://forum.doityourself.com/showth...hreadid=159797
http://forum.doityourself.com/showth...hreadid=147262
WATER HEATER DRAINING AND FLUSHING INFO:
http://forum.doityourself.com/showthread.php?t=159797
Anodes:
http://www.waterheaterrescue.com/pa...ter-anodes.html
Hot water heater troubleshooting | Rotten-egg solutions
Tank less Links:
Real Goods - Solar and Green Living - Online Catalog
Electric Tankless Water Heaters - Stiebel Eltron
Niagara Industries Inc - Titan Electronic Digital Tankless Water Heater
Eemax Tankless Water Heaters
Tankless Water Heater by Stiebel Eltron ~ ~ Go Tankless Water Heaters
You will find some assistance in the following sites:
Always consider the warranties and future service needs for any major appliances you may be considering purchasing. Price isn't always the best guide for the long term.
Sloan Valve Company
Anodes:
Tank less Links:
