Toilet tank fill valve leaks at top during flush but not after
Old 09-10-10, 01:19 PM
D
I've been hearing a dripping sound in my toilet tank during a flush, so I decided to take a look at what was happening in there. When I flushed the toilet with the lid water began to steadily drip out of the top of the valve, but when the float closed the valve after the tank filled the leak stops.
The toilet functions normally and no water is leaked out of the tank or wasted; the leak from the top helps to refill the tank. Because of this I'm not motivated to replace the valve (I assume that's what I'd have to do to fix it). If I continue to ignore this, what's the worst that could happen?
I don't think I want to ignore this indefinitely; it's just a matter of prioritizing. If I need to make it a high priority to fix these toilets I'd really like to know.
Thanks.
Old 09-10-10, 01:39 PM
Gunguy45's Avatar
Super Moderator
It may be entirely normal....I've seen valves where lots of water came out the top to fill the tank.
If it's a Flushmaster...I don't think they do that. I'd put it on the list maybe...but it would be pretty far down. As long as the float valve works and it doesn't leak or refill w/o being flushed....no sweat.
