Getting rid of Insinkerator Garbage Disposal
Received 0 Votes
1/3 hp Badger. Broke this morning and flooded my cabinet under the sink. I want to get rid of entirely! Don't need one anyways. Is there something on the market that will just bolt right in and replace it with just pipe? The Insinkerator opening on top seems to be part of the sink. Some sort of adapter needed?
Thanks,
jt
Thanks,
jt
It shouldn't be a permanent part of the sink. There is an adapter that is attached in place of a regular strainer assy that the disposer attaches to. You'll need to remove the adapter put in a regular strainer assy and redo the drain piping.
See the chrome assy at the top of the disposer..that mostly stays on the sink when the disposer is taken out...thats what you'll need to remove. They are attached in different ways...most use some sort of bolts as shown but some use large nuts.
Received 0 Votes
Thanks for fast reply!
Removed the Badger 1 and it was a seam where the bottom is pressed into the outer casing that failed. (maybe some radiator stop leak? LOL) Irritating. Doubt that it is more than 8 years old. I bought this house new in '93 and already replaced the disposal once.
As much as I hate to replace one piece of crap with another, it might be the easiest way to go. My dishwasher drains into the disposal to further complicate things.
I hate plumbing and wish could afford to hire a plumber on my fixed income. Really appreciate forums like this.
Thanks again,
jt
Thanks again,
jt
Go with a step or 2 above the Badger1 Much quieter and better made. By the time you buy all the other stuff...it won't cost much more than getting rid of it completely. It will also be less stress.
Read the directions for install...make sure you break out the plug for the DW.
All you need to do is remove the disposal from the sink. You will then have a standard sink opening that you will install a basket. From the basket you will then need a tail piece with a dishwasher inlet. Then a piece that goes to your main drain. Go here to see mine: Tolyn's drain All in all I bet it will be about $20 (maybe 4 trips to the store
Do it the way that Tolyn Ironhand said, but do not run the dishwasher hose like the way it's showing, it should be comming straight down and then hook into the drain, not laying on the bottom of the cabinet.
Well hey hold on! You can't just remove the disposer and hook up plumbing. You need a new basket strainer..piping..etc.
Depending on your sink..you may need to get a different strainer assy....took me 3 trips to get one that fit correctly. Finally wound up with a fancy one that was almost $20. And does the OP have the tools required to cut the tailpieces, wrench to remove the adapter if needed.
A $60 replacement disposer might be much cheaper and less hassle.
This is why I hate plumbing! So many variables.
Received 0 Votes
Thanks so much for the great replies!
Looks like the best way for a novice like me would be to get another disposal that will be as easy to install as it was to remove. Going to Home Depot this morning. 18 or 20 mile drive and there is a Lowes nearby too. Maybe Walmart has too?
L8r....
L8r....
Dishwasher Hook-Up
Received 0 Votes
Was at Home Depot today and they had the Badger 1 for $79 and the badger 5 for $99. Spoke with several employees and got some interesting comments abt the units and super instructions for eliminating entirely for less than $20. In a nutshell... for years they had no complaints and the expected life of the Badger 1 was close to 20 years. In the last few years they have had many complaints of the casing cracking and leaking on units less than 10 years old.
It might take me a few days to do everything and take pics, but will get back with you. Quite frankly, looks like a piece of cake. The new basket strainer was the most expensive at $10.96 and the pvc pipe with dishwasher inlet only $3.77. Like I said, it might take a few days because have other things going on.
Received 0 Votes
If I had only taken and posted pictures from the very beginning it might have been a single trip to HD.
One other thing... removing the basket. The Insinkerator assembly had a retaining ring that I didn't know about until HD visit #3. Almost took a 4' crowbar to it until sobered up and came to my senses:
YouTube - Insinkerator Basket Retaining Ring
Ahh yeah...I remember that ring...I've only had to replace the basket a couple of times..none recently...so I didn't remember.
That double drain thing is the wierdest setup I've ever seen. If they both go into the same pipe in the wall it seems like it could cause slow draining of the right sink? Well, if it works I guess it works..right?
