Hot Shower, Cold Bath
Old 11-19-10, 04:37 PM
supersonicklutz's Avatar
I have a Peerless tub and shower faucet, I believe it is the cartridge type. The water wasnt hot enough so I rotated the white plastic (0 ring??) piece all the way to the 'hot side'. That worked for the shower but when the water is switched over to the tub spout, it is not as hot as whats coming out of the shower. Whats up with that?
Old 11-20-10, 04:28 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
It is most likely the temperature compensating feature protecting you from yourself. Try mediating the valve adjustment to somewhere between wao and midpoint. I think you will feel somewhat similar water temperatures at both locations. Post back and let us know.
Old 11-20-10, 08:54 PM
It takes a lot more than that to protect me from my self
Thats where it was before I moved it. The shower and the bath were to cold. After, the shower gets hot but the bath doesnt
Old 11-21-10, 06:19 AM
chandler's Avatar
I'm not giving up, but am at a loss as to why a direct connection from the mixing valve to both the shower and tub would have different temperatures. Hopefully one of our more seasoned plumbers will chime in. I'll keep looking as well.
