Shower Valve Question
I am installing a new tub/shower and i was wondering when i solder the shower valve do I put thread tape on the copper fitting that screws in to the shower valve. Or will it melt do to the heat of the map gas torch. thanks
I have soldered right at the male adapters before. You need to remove the cartridge when you solder. The thing I do is have a spray bottle of water and as soon as you solder spray the valve with the water to cool it quickly.
The other way is to solder a short piece of copper to all the adapters then screw them in. Use couplings to connect each leg. But this allows you to wrap a wet cloth around the male adapter. It keeps it cool as you are soldering the coupling. Cool the whole valve before ypu start the next joint.
The other way is to get unions for each leg.
The other way is just get a sweat diverter. Most manufacturers sell both styles.
Mike NJ
Mike NJ
I did use tape on the last one I installed...but I used 4" stubs of pipe soldered to the male fitting first as Mike mentioned. Normally the supplys come in the top or bottom so you'll need to convert from vertical to horizontal anyway.
