barely no water at the tub
Old 07-08-11, 07:27 PM
i had replace a water heater and was barely getting water at the sink and the bath room sink and i change out the ends on the faucets in the rest room and the kitchen sink now i am getting water like i should this is the problem barely getting any water at the bathtub their are two handle when i turn either one i barely get any water hot and cold the main item is behind the wall what can i do to fix this problem without having to knock out the wall
Old 07-08-11, 08:35 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
I think I replied to this for you in another thread.
Its two handle shower only? The shower head is probably clogged. Remove it and try the water. Just like the aerators at your sinks you changed the shower head is like an aerator.
If its a tub with two handles then the cartridges are clogged, or the passage way to the cartridges. You need to remove them and flush the lines and possibly change the cartridges.
Mike NJ
