Bathtub caulk cures then softens after a couple of showers
Hi there. Hoping some one can help me. I have caulked my sister's bathtub four times now and each time the same thing. It cures and then after a couple of showers it softens and becomes gooey. I have ruled out old/defective product as the rest of the caulking done from the same tube in the same bathroom is fine. The last time I did it I had a fan on the area (it was let go for some time) for several days and it appeared and felt dry in behind the tub surround. I also cleaned out ALL the old caulk as well as anything that was wet or goeey from behind and around the area. I used a dental tool. I was determind to NOT do this job again. I was confident that I had it licked and then again after a couple of showers the product turned to goo and in some areas actually split open which is a new thing. Is it possible that because the job was let go for so long that the drywall behind it is saturated or contaminated? Does anyone have any ideas as to what I should be doing to try to seal this area from further water damage? Thank you in advance. Carmen
What is the name of the caulk you are using? I'm guessing you should switch to a different brand/type. If you are trying to caulk on top of gypsum (sheetrock) that is degraded, that certainly wouldn't help the caulking hold, since if the product it is sealed to can still get wet, it will probably not hold the caulking too well.
Is it the joint between the wall tile and the tub you are sealing?
Are you sure the tile grout is in good condition and not letting water 'bleed' through and behind?
DAP. I am trying to seal the area between the tub and surround. It is in good shape but as I said the caulk job was let go a long time and the area/drywall behind it got wet. I am at a total loss here but will try doing it again with Phenoseal and see what happens. If I can't get it cure I AM wondering if the drywall is just so wet back there. Do you know if drywall can get so wet as to not dry out???? Thanks. Carmen
Yes it is probably too wet and not allowing the caulk to dry.
Do you have another bath to use? May take a long time.
You can try the old plastic trick taped along the walls and in the tub to be sure it dont get wet. Possibly a month?????
Mike NJ
Mike NJ
And fold the plastic back when not using the shower so air still circulates... if you try the hair dryer trick don't get plastic tub surrounds too hot!
You could possibly also try a wet/dry shop vac to suck some moisture out, but be careful with that too!
Gypsum is kinda like a sponge...
