Kohler Revival Bath faucet handle leaking ( K-T16119)
Received 0 Votes
http://www.us.kohler.com/onlinecatalog/pdf/116429_5.pdf
So one of hte handles is leaking, perhaps the stem or an O-ring, I can't get the darn handle off to get at the guts under the skirt! I could figure out whats going on if I could just get to it. Anyone have experience with these or Kohler in general with a similar set up? Thanks in advance!
Received 0 Votes
well i will be dipped in ....
How to Repair a Kohler Revival Faucet | eHow.com
I will try this :-) sounds like you're thoughts are on par with this!
Ha, ha... Thats funny.
Yeah when I first started plumbing I could not figure out how to get the high end faucets apart either. But when you been doing them for years its just seems normal to me.
Dont for get the cartridges have a hot and cold. They are not the same. One is left hand threads and the other is right hand threads.
Also the skirts both unscrew counterclockwise so I was wrong there.
Sometimes the troble with unscrewing the skirts, the whole valve through the sink ends up turning. You will see. And getting the handles to line up again can be tricky if you never done it. You will see.
Let us know how it goes.
Mike NJ
Mike NJ
Received 0 Votes
I have a lever that broke after it had become stuck on the hot water side. So I am trying to take off the hot water side skirt and that won't budge CCW. Even though I used a paper towel to try to not scratch the skirt I still did but to no avail... the skirt won't budge so I can't get to the parts inside... Any thoughts?
Received 0 Votes
Kohler Revival Skirt Removal
My handle started leaking at the bonnet. I could not get the skirt off the handle either. Because the skirt is polished and tapered, a strap wrench wouldn't work primarily because it slipped on the polished chrome but also because the strap could not evenly grab the skirt. My solution was to wrap the skirt with duct tape in order to build out the taper and give the strap wrench more to grab onto. Furthermore, I folded the tape in half inside-out so that it grabbed BOTH the skirt and the strap wrench.
It was on so tight I broke my small strap wrench and almost broke my big strap wrench. Watch this video I made:
Kohler Revival K-16102-4A - YouTube
