Water level in stool part of toilet no longer at original level it is very low
Old 05-24-12, 11:20 AM
jfh
jfh is offline
We have 3 Kohler toilets
And in the last few months the water level in 2 of the Toilet bowl/stools, does not fill to normal level.
What would be the problem or cause that the level became lower by almost 1/2 the level?
Thanks for any help
Joe H
Old 05-24-12, 12:37 PM
lawrosa's Avatar
Super Moderator
Received 69 Votes on 61 Posts
Check inside the tank. The hose that goes to the overflow tube fills the bowl after the flush. If its just hanging in the tank that can be your issue.
If the level is normal after flush then gets lower after some time, I would say a partial clogg down the main is causing the water to siphon out.
Let us know.
Mike NJ
Old 05-24-12, 12:48 PM
jfh
jfh is offline
Mike
Thanks,
I will check the hose if it is in or out of tube.
The water level in stool only fills to the new low level and doesn't change after flush. So if the tube is okay it must be something else?
Again thanks for the reply!
Joe H
