Toilet
Old 07-07-12, 06:23 AM
C
Toilet
Recently my toilet is acting weird, after I flush the toilet, the water loads back to the tank normally but keeps on loading and not stopping going over the line limit, I've draw an arrow of the part when it's keep dripping the water
Old 07-07-12, 12:11 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
I am not familiar with that toilet since you are non US. You may have better luck in a local forumn to your country.
What is the make and model or the toilet? possibly I could search around for technical papers.
Old 07-07-12, 06:59 PM
P
Received 684 Votes on 631 Posts
Like Lawrosa mentioned most of us drive on the right side of the road and our toilet parts look a bit different. I suspect that your fill valve is clogged so it cannot full close or the float may need adjusting. If it worked fine before and has recently started over filling I betthe fill valve has a piece of rust or sediment stuck inside. Some can be disassembled and cleaned but usually they are such an inexpensive part that it's easier to just replace it with a new one.
