No hot water from sink and shower. Help pleasssse...
Ok, in one of my bathrooms, the sink and shower does not have hot water coming out. But, cold water comes out fine. Also, when I turn the handle in the shower all the way to the hot side, water stops coming out. The sink has two handles, one for cold and the other for hot. The pipes in the sink are plastic and I don't know what the brand is. For the shower, it's a single handle Moen. When you turn the handle counter-clockwise, cold water is first, then hot water. The water heater was replaced about a year ago. The sink and shower that's goofing up was rarely used before the water heater was replaced. It's never been used after replacement. Any help would be appreciated.
You may also need to remove and clean the cartridge inside the fixture. It's possible the water heater let go a big blob of sediment.
