Is it normal to have a little ring of standing water at sink drain?
Hello, new member here. Found some useful info plus related issues so I just joined. I just changed the sink and faucet in my bathroom (including the drain tailpipe). I just noticed that there always seems to be a ring of water at the bottom of the sink where the drain is, where the surface of the sink meets the flange (or strainer), which I did seal between them with plumber's putty. Is that normal? I didn't notice it in my old sink, but then I don't remember now that it's been replaced. Nothing is leaking underneath the sink and it's not clogged (because it's just been replaced, along with the drainpipe). So I wonder if it's just the quality of the sink, or if it's typical, or maybe my water is too hard (which I know it is), so it's just staying at the bottom the sink, just a small ring, so I should just treat it as normal and let it dry or wipe it dry, which is ideal, but realistically who keeps wiping a sink dry after every use?
I checked the sink at my other bathroom which I also replaced with an identical sink, drainpipe, and faucet. No leaks either, just collects a little water at the bottom of the drain too, but not a perfect ring or circle around the drain like the other sink I'm talking about above, but the water collects slightly on one side of the flange (strainger), not like a "full moon" above, like a half-moon, so I'm assuming part of it has to do with the pitch of the sink, where the first sink is more perfectly level than this one which is why water tends to collect in a perfect circle around the drain of the first sink I'm describing above.
Nothing leaks in either sink or drain assembly in the process, so not sure whether to be anal and try and re-pitch the flange and drain slightly in the first sink so it drains like the second sink, or just leave things well-be alone.
Here's pics of what I'm talking about, the first one is the water collecting around the drain:
Mastersink | Flickr - Photo Sharing!
The second one below shows the guest bathroom's sink not collecting as much, but still a little to the side:
Guestsink | Flickr - Photo Sharing!
Depending on how the sink was molded, the drain assembly and how much putty you used under the drain flange this could be normal.
I think you are okay. I can't remember off hand but I think my bathroom sinks also hold a bit of water like yours do. I know that over a week or two they will develop a reddish ring of harmless bacteria and that I can wipe it out easily with a small wad of toilet paper.
IMO from the pic and the strainer void in the sink, the wrong strainer was used for that sink. Most are universal but certain sinks need OEM strainers IMO.
Yours doesn't look plastic but I have installed lavatory faucets that came with plastic tail pieces that had a flange so thick* no way it would set down completely in the recess. Usually a brass tail piece which had a much thinner flange solved the problem. I did though once encounter a lavatory sink so badly cast with almost no recess that even a brass tail piece wouldn't work.
*Plastic for reasons of strength needs to be thicker. Just can't make plastic as thin as metal.
My reason is that if its say a Kohler sink a Kohler strainer should be used. You can see on this strainer how the curve would adapt to the specific brand sink. This strainer is curved up more and the diameter is also sink specific.
Hope this helps.
.plumbingpartsstore.com
Hope this helps.
