Cultured Marble Shower Floor Pan Cracked/Glaze Peeling
Received 0 Votes
I have a cultured marble shower floor "pan" that was cracked when we moved into this house and since the glaze has started to peel.
I would like to know if the shower floor can be sanded and reglazed or would I need it replaced.
Would the cultured marble walls have to be removed to replace the flooring? I seen a company that puts a liner down over the old shower floor and it looks great but...do the cracks indicate a more serious problem? I have a slab foundation and the house was built in 2003. If two of the marble panels were removed (one side is a bench seat) could the old shower floor be removed and a replacement slid into place and new walls installed?
Temporarily Suspended
Received 0 Votes
It may be possible to repair the floor but you would need a company that specializes in marble unless you can rent the proper machine & disc. As far as I know, you can't sand it the way you would with other materials.
Received 0 Votes
I really don't know why it cracked, it was cracked when we moved in...but we did have an earthquake and the slab beneath the house literally rolled.
A thought occurred to me today, on youtube I seen a dealer tell about putting on a liner over the cracked marble shower floor and I thought, what the heck, formica (no) or a thin sheet of white plastic with contact cement neatly fitted and siliconed... There has to be something other than a $4,000 shower replacement.
Received 0 Votes
Well, I had a guy come by today that works for the company that installed the shower and he said the cracks in the shower floor were the result of leaks where it wasn't caulked properly. Most importantly, he said they could put and "overlay" in at a cost of $365.00 that would cover the cracks and entire shower floor and look new again. Not a resurface, but an overlay. Still by far more reasonable than a complete new shower...
Received 0 Votes
No, the two homeowners before me didn't do any maintenance on the home. They never asked for warranty work from the builder like the deadbolt on the garage door never was set to where the bolt would enter the "slot" and I had to reset the striker plate. Little things like that here and there i had to fix or adjust.
And, the shower needs to be caulked every 12-18 months regardless. So it wasn't their fault, the homeowner has responsibilities too.
